Using Tube with Meike Reverse Adapter?
geffect
Post by geffect » 30.01.2018 13:53
I would like to know if it is possible to use the tube together with the Meike Reverse Adapter (http://www.meikestore.com/product/meike ... /2827.html).
I would like to reverse the Canon 40mm Pancake to get approx. a 2:1 and to able to shoot with the tube, I thought it might be possible to use the Meike Reverse Adapter.
So the configuration would be as follows:
Canon 7D Mk2 => Tube => Meike Reverse Adapter => 40mm Pancake
Do you know if the signal is being processed as expected through the Meike adapter?
Daniel
Re: Using Tube with Meike Reverse Adapter?
Post by Stas Yatsenko » 01.02.2018 21:50
Hi Daniel,
we didn't test the tube with this or a similar reverse adapter. Theoretically this combination might work, since this reverse adapter supports AF function and the lens has a built-in motor, which is the main requirement for the lens to be compatible with the tube. But this can only be checked experimentally.
