D850 with ipad
Pixelbound
D850 with ipad
Unread post by Pixelbound » 22.12.2017 11:50
Hi there
Is it possible to use the ipad version of helicon remote with the nikon d850 and if so, is there a guideline available?
Steven
Re: D850 with ipad
Unread post by Stas Yatsenko » 23.12.2017 12:10
I think it's possible, but a bit tricky because of the Snapbridge app being involved. We don't have detailed instructions because we don't have a D850 body, but it goes along the lines of:
1) Run Helicon Remote. Do NOT run the Nikon remote control app, make sure it's not running.
2) Use Snapbidge to activate Wi-Fi in the camera body.
3) Connect to the Wi-Fi network hosted by the camera.
4) Switch to Helicon Remote. It should detect the camera. Press "Select a camera" and tap the "auto-detected Nikon camera" item to connect to the camera.
Pixelbound
Re: D850 with ipad
Unread post by Pixelbound » 23.12.2017 12:27
hi Stas
Tried this but does not work. From the moment you leave the snapbridge app the camera’s wifi signal stops. Shame. Nikon should build helicon into their snapbridge app, would be much more convenient than their focus shift they now have in the d850, a silly way of working since you can’t fix start and end focusing points! I prefer your software, but a pity you always have to carry a laptop with you.
Will the ipad app ever work with Fuji XT2?
Steven
mrose
Re: D850 with ipad
Unread post by mrose » 24.12.2017 12:49
I have already posted this :This man demonstrates it working for QDSLRDashboard. He says it works with version 2.01 as well as the 1.3 demonstrated.
https://www.youtube.com/watch?v=oFum1ogPW-s
"Connecting the D850 to a Mac using Snapbridge on an iPhone using Snapbridge as interim connector Once you have connected the D850 to the Mac or any second device, you can even turn of the device that runs Snapbridge.
1. Prerequisites An Apple mobile device running the Nikon Snapbridge App. Android doesn't work as it connects directly to the Nikon D850 on the first device A second device running qDSLRDashboard that is able to connect via WiFi
2. Camera setup increase C2 value to 1 min Increase the C4 values Menüs and Information display to 1 min
3. Start the Snapbridge app on the iPhone/iPad Before clicking on 'Camera' to enable WiFi, check if the camera has recognized the connection, as well. Setup Menu - Bluetooth. After clicking on 'Camera' in the app, select 'Remote photography' to turn on WiFi on the camera. This should take not more than 15 s. You're getting a screen "The device will connect to the camera via Wi-Fi...." Stay on this screen. Once you got this screen, you're done on the iPhone/iPad. You have successfully turned on WiFi on the Nikon D850 and your second device is ready to connect. Stay on this screen until the second device has connected to the D850 WiFi and you have opened and connected qDSLRDashboard.
4. Set up the second device with qDSLRDashboard Connect the device to the Nikon D850 WiFi. Open qDSLRDashboard Click on 'Nikon' and qDSLRDashboard connects".
Pixelbound
Re: D850 with ipad
Unread post by Pixelbound » 25.12.2017 14:07
Hi, thanks very much. This works, I can fire up the wifi of the D850 from my iPhone, and then connect to it with Helicon remote on an iPad.
However, I can't figure out how to fix the focus points. I click on the first, and then it is locked, but I can't click on the second to fix it. So I can't start shooting the sequence either. I looked everywhere for a tutorial but nothing on the web…
Can anybody help here?
Re: D850 with ipad
Unread post by Stas Yatsenko » 26.12.2017 12:13
Thanks for reposting that Snapbridge trick. It slipped my mind that you need a second physical iOS device.
As for the focus points: after locking one of them, you must use the manual focusing buttons to navigate to the other one (<, <<, <<< / >>>, >>, >). You cannot use autofocus or rotate the focus ring by hand. Well, you can, but the app will not register that focus shift, so nothing will work.
mrose
Re: D850 with ipad
Unread post by mrose » 26.12.2017 13:04
Also the tutorials are on the web....
http://www.heliconsoft.com/helicon-remote-help-online/
