Accurate focusing in zoomed view
peter3015
Unread post by peter3015 » 18.12.2017 08:53
Release 3.9.2 fixed a bug where accurate the trigger point for accurate focusing was not in the osition of the screen tap. The upgrade improved the accuracy of this process but the issue is still there. Is this likely to be addressed in the next upgrade.
Canon 750D,
iPad mini 2 iOS 11.2.1
Re: Accurate focusing in zoomed view
Unread post by Stas Yatsenko » 18.12.2017 13:43
As far as I know, there is no issue in the app, the inaccuracy you're observing is likely that of the contrast AF function itself. But we will re-check this.
peter3015
Unread post by peter3015 » 19.12.2017 22:17
Thanks for the response
It was working accurately on zoom before the 3.9.1 release but then was unusable in 3.9.2. You make a change after the initial 3.9.2 release and that rectified the problem making the zoom focus point locatable off to one side.
Previously this function has been very accurate where the zoom screen displayed the tapped focus point in the middle of the zoom screen.
Would it help if I sent some screen shots?
Unread post by Stas Yatsenko » 20.12.2017 15:50
Screenshots probably won't help. Thanks for pointing out the issue, we are investigating it.
