6k Photo
manfred
6k Photo
Unread post by manfred » 25.04.2017 17:38
Do you plan to support the 6k photo mode from the Panasonic Lumix GH5?
Re: 6k Photo
Unread post by Stas Yatsenko » 26.04.2017 13:01
Yes, it will work in the next update. Or you can download the latest ffmpeg utility yourself and put it into the Helicon Focus folder, that will enable Focus to import the video.
Clipping path
Re: 6k Photo
Unread post by Clipping path » 08.10.2017 19:17
Stas Yatsenko wrote:Yes, it will work in the next update. Or you can download the latest ffmpeg utility yourself and put it into the Helicon Focus folder, that will enable Focus to import the video.
that means what are we doing manually right now , on the next update we don't have to do that manually?
Re: 6k Photo
Unread post by Stas Yatsenko » 09.10.2017 15:19
I cannot answer that without knowing what it is that you're doing manually.
I assume the problem was that the videos could not be opened by Helicon Focus, it should no longer be a problem with the new Focus 6.8.0 which you can download from our website: http://www.heliconsoft.com/software-downloads/
Clipping path
Re: 6k Photo
Unread post by Clipping path » 09.10.2017 20:16
Stas Yatsenko wrote:I cannot answer that without knowing what it is that you're doing manually.
yea..that's what i am asking about. and thank you for the answer. :)
