render error 5
bsarver
render error 5
Unread post by bsarver » 18.07.2016 18:24
I have been shooting a series of microprocessor chip sets with Helicon Remote and processing them in Helicon Focus and they have been working perfectly. After 30 image stcks processed without errors and with no changes in settings, equipment or anything else, I am now getting an internal render error 5 on a new stack. When I open the images in the stack, I see that every other image is rotated. My camera is a Canon 5D Mark III with MP-E 65mm with Stack Shot 3x. I have verified that auto rotate is off. I have also tired it with autorotate on, and am getting the same error.
How can I resolve this issue?
Re: render error 5
Unread post by Stas Yatsenko » 19.07.2016 10:33
The problem is probably with the image orientation EXIF tag. You can fix it with some image editing software. The root cause must be the camera body - disable the orientation sensor in the body settings.
MikeCT
Re: render error 5
Unread post by MikeCT » 26.07.2016 16:37
bsarver
Are you working on a copy stand? I had a similar problem because, when it is pointing straight down, the camera cannot decide if it is in portrait or landscape mode. I solved it by tilting the entire stand a few degrees.
David Edge
Re: render error 5
Unread post by David Edge » 25.09.2017 16:59
I'm having the same problem on a copy stand and the "tilt the whole lot" suggestion sounds like a good Plan B.
Does anybody know if Stas's Plan A - disable the orientation sensor on the body - can be done on a Nikon body without a soldering iron?
d.
Re: render error 5
Unread post by Stas Yatsenko » 26.09.2017 09:19
Look for something like "Auto Image Rotation" in the camera body settings, or in the user manual for your body. There should be such an option.
David Edge
Re: render error 5
Unread post by David Edge » 26.09.2017 12:04
Thanks Stas - that's it. I was thinking that was the same as 'rotate tall' which controls playback on the LCD screen. ta d.
