Ver. 5.2.7 Is Out. What Changes?
jpmccormac
Unread postby jpmccormac » 30.01.2014 19:57
I see that Helicon Filter 5.2.7 was just released. I wonder if Stas could tell us a bit more about the changes and improvements in this version. Thanks.
jpmccormac
Re: Ver. 5.2.7 Is Out. What Changes?
Unread postby jpmccormac » 30.01.2014 20:49
I thought I'd give 5.2.7 a try, but it's a mess on my computer (Win 7 Home Premium, 4 GB RAM). I only have presets on the edit menus, no access to the expert modes. Where are the edit tabs that used to be on the top level menu. They are gone!!!
Edit/Update. After manually deleting the old version of HF and deleting all the User files and caches and registry items, I finally got HF 5.2.7 working properly.
Unread postby Stas Yatsenko » 03.02.2014 13:39
Ok, thanks for update. I doubt we can reproduce this bug, we never have seen this while testing.
kyakom
Unread postby kyakom » 03.02.2014 17:33
After update 5.2.7 works very slowly. Before the upgrade program was fast, and now a long time to wait for anything. Please do something about it.
Unread postby Stas Yatsenko » 05.02.2014 11:46
I would appreciate if you give us more information to reproduce the problem. Is the program slower when browsing folders, when opening images or when applying filters? Please check with different files and see if this has any influence. You are welcome to install previous version into separate folder to be able to compare two versions side by side. Here is the link to older version:
http://www.heliconsoft.com/downloads/HeliconFilter5.2.6.exe
