Interface - Inconsistancy
Orion
Unread postby Orion » 11.09.2013 04:02
Helicon Filter 5.2
Step ONE - I Opened & Cropped a HS50EXR Raw Image and Clicked "Apply"
( It Showed Up on the History Tab & Looked as it Should )
Step TWO - I Clicked the "Auto Brightness, Saturation & Sharpening" BUTTON
( Which was Showing on the Right-Side Menu Bar )
Clicking the Step TWO Button CAUSED the HISTORY Tab Listings to RESET & the Previously Re-Sized Image to Return to FULL SIZE and THEN it Applied the Auto Brightness, Saturation & Sharpening Corrections.
This Result is a bit Retarded or Backward !
Please Check it Out - Maybe this Could Be Easily Corrected. . .
Cheers from Orion :D
Re: Interface - Inconsistancy
Unread postby Stas Yatsenko » 12.09.2013 11:32
Thanks for your report. We will fix it.
