How do you clear the Run folder in Helicon Focus, without deleting from the disc please ?
Col
How to clear the folder in HFocus ?
Re: How to clear the folder in HFocus ?
go into parameter mode. click the file tab and then choose "clear source list." this will not remove the files from your disk. it will just clear the links from hf.
almost forgot to mention: you can then go to another folder and then "add new items" from wherever you want. it's more convenient if you have the images from each stack in separate folders.
Works a treat, Thanks Jim.
Yes, separate folders is the way to go.
Col
Col
