Micro-photo du pauvre
Laglue37
Post by Laglue37 » 14.04.2013 13:53
Voici un exemple de realisation sur mon "" banc micro de recup""
plus de détails si interet
Le stacking
See you soon
Laglue37
Re: Micro-photo du pauvre
Post by Laglue37 » 18.04.2013 22:26
Another one , from my job
I work in pleasure.
Laglue37
Post by Laglue37 » 04.08.2013 10:42
Un essai presque aux limites du montage , il y a 52 cm entre le capteur et le sujet.
Que cache t'il sous ce tee-shirt bien connue.
Rien du tout , il faut bien masquer les lumières exterieures
Evolution du support sujet
Le résultat final pour contrôle & mesure Gx de 16 record battue
Post by Stas Yatsenko » 06.08.2013 11:50
Interesting setup! Which magnification did you get?
Laglue37
Post by Laglue37 » 10.08.2013 16:31
Hello
With a 50/ 1.8 objo in inverse i Got a Gx around 15.
The lenght betewn D70 and objo and subject his about 50 cm due to lenght of wood support .
I have made some test with a 28 mm ,it work fine but more difficult to use.
The deplacement of subject is command by the gear of an old CD reader (very easy control on)
I hope you can understand my poor English
Salutations
Post by Stas Yatsenko » 14.08.2013 13:08
How do you control CD gear? Which interface and software?
Laglue37
Post by Laglue37 » 02.09.2013 09:52
Hello , no electronic on the desk , only a finger on the motor gear , one tough (dent) by one , .
I construct this ""banc"" to answer to members of a forum , they find it was to difficult or expensive for the construction or buying.
@micalement
Bernard
