Linear actuator
jdaniel
Linear actuator
Unread post by jdaniel » 11.07.2012 13:21
I have been using the demo version of Helicon with an inspection microscope for the past few weeks now and have had great results!
I am now looking at automating the stack acquisition. I currently have access to a range of linear positioners and wonder if it is possible to interface these with Helicon?
http://www.thorlabs.com/NewGroupPage9.c ... up_ID=2419
http://www.thorlabs.com/thorProduct.cfm ... mber=Z825B
Falling that I wonder if anyone could recommend an alternative linear actuator for this purpose, has anyone else found an easy to interface with a microscope? I have looked at slackshoot but the positioning system is too bulky for the job.
Re: Linear actuator
Unread post by Stas Yatsenko » 12.07.2012 10:53
Sorry, these actuators are not supported. You may look for gear based on Trinamic stepper motors, that may work.
Stephan Wolfsried
Re: Linear actuator
Unread post by Stephan Wolfsried » 27.08.2014 10:57
Maybe this article helps.
http://www.mindat.org/article.php/2066
Cheers Stephan
George Langford
Re: Linear actuator
Unread post by George Langford » 10.09.2014 17:18
Regarding automation of the interface between HF and a microscope:
1. On my Olympus stereomicroscope, I added a stage to support the object and a dial indicator with one inch range reading in 0.001 inch increments easily resolved to follow the head of the microscope. For some pix I move the head 0.001 inch at a time at 35X and as much as 0.005 inch at a time for low magnifications. My Olympus camera can be operated with its internal self-timer to expose the image as few as three seconds after I press the shutter release. The exposures range from one second to 1/125 second, depending on the object. This gives nice results, and most of my time is spent waiting for those three-second delays to expire. It's all very flexible, and the object stays in place just fine.
2. On my metallograph everything is just about the same (same camera, for example) except that I use the calibration of the fine focus knob to space the stacked layers. At high magnifications, the increments have to be in fractional microns (0.001mm) but the results look like color scanning electron microscope images at similar magnifications. Same three second delays between exposures, but sometimes a great many images, say 200. HF never chokes on this quantity of images. My light source is a one watt white LED. I'm limited only by the working distance of the objective lens.
The first Olympus camera logged more than 20,000 images using HF. I'm now using another Olympus camera (E-620) because it has Live View, which saves a lot of guesswork about where to start the stack.
George Langford
Re: Linear actuator
Unread post by Stas Yatsenko » 15.09.2014 12:19
George, do you still have problems with long stacks (200+) using the latest Helicon Focus version? We have not heard such complaints before.
