error on saving image
jimshirey
Unread post by jimshirey » 15.08.2011 00:39
i keep getting the message:
"error on saving image <filename> Access violation at address 00AEA186 in module PolyImagePro.dll. Read of address 00000004."
normally i ignore it and it doesn't seem to make any difference. but today it crashed the computer, last time this happened i just reloaded the software and it didn't happen again until recently. since then i make sure to restart my computer in between stacks.
i am using XP service pack 3, loading stacks of 12 to 80 canon raw files, about 20 mpx each.
any ideas?
Re: error on saving image
Unread post by Stas Yatsenko » 16.08.2011 10:20
We get similar reports when saving results in TIFF format with LZW compression. Is this your case?
jimshirey
Unread post by jimshirey » 22.08.2011 16:36
i am using the "TIF" format option when i save the hf output, not "TIF LZW." would it be better to use the "psd" format option?
Unread post by Stas Yatsenko » 25.08.2011 13:18
We were able to reproduce bug with TIFF LZW but not with uncomressed TIFF. Saving PSD is also lossless and produces the files of similar size. You can use it as well.
jimshirey
Unread post by jimshirey » 03.09.2011 05:42
i'll try the psd, though the tif would better suit my purposes. however, in my last run the tif i got was a very tiny file, completely useless, and i had to start from the beginning. this seems to happen only when i stack the raw files, not when i stack the jpgs. but i only had about a dozen files in the stack. could this be a problem with limited ram?
Unread post by Stas Yatsenko » 05.09.2011 11:02
Most probably this happens because RAW files were not converted correctly. If the program is not able to read RAW file, it opens a small thumbnail image inside of it. Helicon Focus (win version) has several raw converters (see Preferences/RAW) I would recommend to try different one. You can also convert raw files to tiffs and process tiffs. If you call Helicon Focus from Lightroom, this convertion is done automatically.
