System out of application memory - Mac High Sierra
diksouan
Post by diksouan » 11.09.2018 20:28
I'm trying to stack 426 raw files from my Canon 5D IV. Gets about 2/3 through and stops. Says system has run out of application memory.
I have a MacBook Pro 2.8 Ghz i7, 16 GB RAM, 4 GB VRAM, 2TB SSD, 170 GB available, and external 128 GB Flash/SSD USB3 drive set as Helicon Focus Cache. Got same result before adding external.
How do I allocate more application memory?
Re: System out of application memory - Mac High Sierra
Post by Stas Yatsenko » 12.09.2018 10:12
Are you running Helicon Focus 6 or 7? You can see the program's version in the window title. If it's 6.x.x, use the new Focus 7.0.1 instead: https://www.heliconsoft.com/downloads/HeliconFocus.dmg
If you're already using 7.0.1, or the problem persists, go to Preferences -> Performance, set "Memory cache limit" to zero and try again. Get back to us if that still doesn't help (but it should).
