Huawei P20 Pro and FB tube programming
Locked
photosbykev
Post by photosbykev » 22.07.2018 12:46
I'm interested in buying the FB tube for use with my Canon 5D4 and range of Canon lens.
I use a Huawei P20 Pro smartphone which doesn't have a 3.5mm audio output but it does have an IR transmitter built into it.
Has anyone had some success using this phone to programme the FB tube?
regards
Kev
http://www.photosbykev.com
Re: Huawei P20 Pro and FB tube programming
Post by Stas Yatsenko » 26.07.2018 10:25
No, unfortunately, the built-in transmitter will not work. We’ve made tests on P20 recently, but faced problems configuring the tube due to low signal strength which is not sufficient for successful data transmission. In a couple of weeks we plan to launch sales of a modified tube that will use different connection principle. We assume P20 should work fine with this new tube and USB to 3.5mm jack adapter.
photosbykev
Post by photosbykev » 26.07.2018 10:44
Stas Yatsenko wrote:
26.07.2018 10:25
Thank you for the update Stas, how can i get notification to buy the revised FB Tube?
regards
Kev
Post by Stas Yatsenko » 27.07.2018 15:15
We are going to start selling in a few weeks. Follow our website.
Locked
