Artifacts
haraldmuc
Artifacts
Post by haraldmuc » 12.12.2016 13:00
I have stack with 48 shots in Raw (f 3.2). After processing the files you can see many artifacts, I have tried all three available methods with different settings für radius and smoothing but no luck so far. Does anyone have an idea what goes wrong here?
(3.2 MiB) Not downloaded yet
Re: Artifacts
Post by Stas Yatsenko » 13.12.2016 16:23
Please upload your stack to our server (as described at http://www.heliconsoft.com/ftp-server/).
haraldmuc
Re: Artifacts
Post by haraldmuc » 15.12.2016 17:25
I uploaded the files yesterday! Thanks.
Re: Artifacts
Post by Stas Yatsenko » 16.12.2016 16:45
You probably mean blurred area on the edge of white crystals? This is mostly due to optical effect. I would recommend to decrease aperture to f8 or f11 to minimize this effect. This will also help to remove blurred areas which appear because focused areas do not overlap sufficiently.
From our tests, method C gives best results for the current stack.
haraldmuc
Re: Artifacts
Post by haraldmuc » 16.12.2016 20:16
Thanks very much for your reply, this should help.
