First try
OzanK
First try
Unread post by OzanK » 12.07.2015 23:16
Hi to all ... I'm struggling for focus stacking for three hours, but unfortunately I can not get successful results. One of the examples of my work is the following. This image is the result of 16 frames. What do you think? Where do I make wrong? Thanks a lot.
Re: First try
Unread post by Stas Yatsenko » 13.07.2015 11:56
OzanK
Re: First try
Unread post by OzanK » 13.07.2015 17:47
Hi Stas ... I've just recognized that when I open my .CR2 files from Lightroom (by Plug-in Extras > Export to Helicon Focus) I'm getting bad results. But, if I open my files directly in Helicon focus, the result is good ... at least acceptable for a newbie.
So, the problem is appearing when I start Helicon Focus in Lightroom ... what can I do for correcting it?
Additionally, is Helicon focus available as Photoshop filter plug-in?
Re: First try
Unread post by Stas Yatsenko » 14.07.2015 09:58
Try to set Lightroom to export files in DNG format, here is printscreen:
http://www.heliconsoft.com/support/mms/12512784.html
You also need to install Adobe DNG Converter: http://www.heliconsoft.com/adobedng/
and setup the path to DNG Converter in Helicon Focus menu "Preferences / Integration".
Please also follow these links:
http://www.heliconsoft.com/focus/help/e ... _Lightroom
http://www.youtube.com/embed/PQLAyW1q7po
http://www.youtube.com/embed/Xj7lwMG7o9c
http://www.heliconsoft.com/raw-in-dng-out/
Helicon Focus does not available as Photoshop filter plug-in.
