Best settings for stacking images of flowers
k93
Post by k93 » 20.03.2014 21:44
I make a lot of closeup images of flowers and details of flowers. I have started doing focus stacking, using from 3 to 8 stacked images. I have just started using Helicon Focus and would like to know what the is the best method and settings for flowers such as roses or dahlias. So far I have found the following two to work best:
1. Method B with a Radius of 8 and Smoothing of 2
2. Method C with a Radius of 4
Re: Best settings for stacking images of flowers
Post by Stas Yatsenko » 24.03.2014 12:23
Yes, flowers have lots of edges and intersecting details so method C should give best results. I would recommend to try method B with different Radius settings.
rushless
Post by rushless » 10.03.2015 20:55
I've recently purchased the software and been working with flowers. I agree that method C is best, I cannot get methods A or B to have complete focus, at least compared to method C. With C I can get fine hairs on flowers to show up!
I'm tagging to this post, wondering if anyone has tips on setting A B ranges for flowers in Heilicon Remote. Using a lens, not a stack rail. (100mm 2.8 canon macro).
I've found difficulty with white flowers, in particular.
Any tips on how to look at the situation I'm framing and determine nearest and farthest points? I've found this easier when I'm using a fairly straight on or straight down shot, but my mind is having issues picturing what to set as A and B for nearest/furtherst.
Thanks!
jsp
Post by jsp » 28.03.2015 15:09
I'm also having trouble with white flowers. Any tips gratefully received.
plum
(8.61 MiB) Not downloaded yet
rushless
Post by rushless » 28.03.2015 19:11
The best I've found so far is using continuous daylight but that's pretty dang hard to time and shoot.
I realized that if the program has trouble with varying light levels in the different stacks that it would have difficulty finding the overlapping edges on a pure white object that's reflecting the light.
I could be wrong, but that's my best guess so far. I just told a client I couldn't do white flowers >_>
rushless
Post by rushless » 28.03.2015 19:24
I have to change my comment a bit, I hadn't downloaded your image.
Now that I do:
- Have you tried all three methods of stacking?
- I found C works best for fine detail but A works best if you want some contrast and colors still.
- Try isolating your background better too!
