Halos around flares
alexey05
Halos around flares
Post by alexey05 » 08.02.2014 11:43
Always when i try to blend photos with flares it ended with big sized flares taken from blured part of images. First image with problem, secon image is the ordinary raw focused in proper place
(162.21 KiB) Not downloaded yet
(200.58 KiB) Not downloaded yet
Can it be somehow avoided?
Re: Halos around flares
Post by Stas Yatsenko » 12.02.2014 12:12
I think you should experiment with method B and different values for the Radius. Though, I suspect this can only minimize the problem. I would appreciate if you upload the stack to our server (as described at http://www.heliconsoft.com/ftp-server/). We will check if we can adapt algorithm to deal particularly with flares.
alexey05
Post by alexey05 » 14.02.2014 17:01
Thank you Stas, i upload it to Alexey Fursov directory on your server
Post by Stas Yatsenko » 18.02.2014 13:34
Hello Alexey,
Thanks for the stack. I found that bigger radius and method B produces best results. I've also found that our new version which is not yet published, which has RAW development settings, produces such source images that give much better results. So I would recommend you to wait about a week and take another try with your stack.
