saving and loading projects
jimshirey
Unread post by jimshirey » 22.08.2011 16:46
how exactly do i save and then retrieve a project? i've attempted everything i can think of and i've never done this successfully.
Re: saving and loading projects
Unread post by Stas Yatsenko » 25.08.2011 13:18
First of all, this functionality is available in trial, Pro or X64 version for Windows and not available in Lite version and for Mac.
You should load the stack, process it and then you can save it via menu\File\Save project.
The primary goal of this functionality is to allow you save project to be able to continue retouching later.
coffeemug
Unread post by coffeemug » 26.04.2012 17:14
Seems like an annoying thing to miss in the Mac version? Especially if the retouching is time consuming.
Do you have plans to implement this for the Mac?
Unread post by Stas Yatsenko » 28.04.2012 10:59
Yes, we are working now on the new version where this is implemented. It is is developement stage but we can put your address to beta tester list so you will among the first to test new functionality.
coffeemug
Unread post by coffeemug » 28.04.2012 13:16
Stas Yatsenko wrote:Yes, we are working now on the new version where this is implemented. It is is developement stage but we can put your address to beta tester list so you will among the first to test new functionality.
Yes please, I would like to test it :)
