Problem
Paolo
Problem
Post by Paolo » 09.01.2011 18:12
Ciao,
i’m Paolo, photographer from Italy.
I have photographed a shell fossil tall 2,5 centimeters.
I have realized 28 photos on tripoid.
The elaboration with helicon focus has not given satisfactory
results and I doesn't understand where is the problem.
I send you an image with marked in red the problems.
Could you explain me where I have been wrong?
Grazie
Paolo
Re: Problem
Post by Stas Yatsenko » 10.01.2011 11:45
Please upload downsized to 2Mp .JPG source images to our ftp server as described on http://heliconsoft.com/ftp.html
Paolo
Re: Problem
Post by Paolo » 10.01.2011 15:48
Grazie Stas.
I have uploaded the file.
Paolo
Re: Problem
Post by Stas Yatsenko » 13.01.2011 12:57
Thanks for the samples. I see that you use Manual exposure mode and the same parameters for all your images, which is good. Still, the images have very different brightness and the program was not able to correct brightness changes. Most probably because white background and object itself change the brightness differetntly.
This variation of brightness may be a result of moving the flash or firing flash with auto mode.
jimshirey
Re: Problem
Post by jimshirey » 06.08.2011 10:23
this looks like brightness variation when you are shooting. i get this all the time, as i use only natural lighting. the only way to fix it is by retouching.
