workflow question
workflow question
Unread postby fabforrest » 15.11.2008 17:53
i use a canon EPS 1D MkII and process using Aperture on a Mac Pro. Is the best workflow to import into Aperture and do RAW processing (same for all images in the set) and then export images and bring into Helicon Focus?
fabforrest
Unread postby Dan Kozub » 20.11.2008 14:22
Yes, I would recommend to convert and then process. Helicon Focus can read RAW files if they are supported by OS so you can use RAWs directly.
Unread postby Guest » 20.11.2008 17:38
thanks. am i correct the Leopard is not yet supported (but will be soon)?
Guest
Unread postby Dan Kozub » 21.11.2008 09:52
Current Mac version works fine on Leopard too.
Return to Helicon Focus: Macro
