Export to photoshop CS4
Unread postby TonyB » 13.11.2008 11:55
Hi, What a contrast to the CS4 implementation - this has worked every time! Tried supper as a subject before it was cooked.
One problem area, I can drop raw (Nikon NEF) files straight into the source box, they are processed OK, save as Photoshop file (.psd) and the resulting file is "jumbled" (not corrupt - it will open in PS but is a "mix" of pixels. Saving in any of the other options works fine. Using processed (e.g. jpeg or tiff) files as source results in a normal PS file. I'm using CS4 on an Intel G5
Photoshop save
Unread postby Dan Kozub » 20.11.2008 14:25
Yes, there is a bug in PSD export which we cannot fix directly and have to find workaround. I would recommend you to use 16 bit tiff which is the same as PSD in this case (or better?).
