cannot figure this out
harmany
Unread post by harmany » 11.08.2008 06:05
I am trying to make an image but it looks like huge blocks of pixels. It was a flower, and i tried to follow the instructions, which are simple. But i am lost. What do you do to finish the image, i hit run, it goes through the motions, but just wee these big squares.javascript:emoticon(':cry:')
thanks
Joyce
Unread post by Dan Kozub » 11.08.2008 14:30
Joyce,
This can happen if you process RAW files and the program is not able to open files correctly. It uses embedded low resolution thumbnails instead. If this is the reason please convert your RAW files to tiff or jpeg before processing.
In the recent 4.50 version we added new Adobe RAW converter so make sure you are using the latest version.
harmany
thanks
Unread post by harmany » 13.08.2008 05:58
Thanks for the tip, i will give it a try, i just downloaded the program the other night, so i should have the latest version. But i will convert to tiff and see what happens.
Joyce
