A few images !
JPS
A few images !
Unread postby JPS » 26.05.2008 14:23
Some images that i have done lately, using Helicon Focus !
Nikon D200 + Tamron SP90 - 1:250 @ f8 with flash - 7 shots
Nikon D200 + Tamron SP90 - 1:250 @ f8 with flash - 15 shots
Nikon D200 + Nikkor 55mm. f/2.8 Ais - 1:250 @ f8 with flash - 18 shots
Length of the bench: 1.70 m. / 63 inches
100%crop of previous
100% crop of previous
I'm VERY hapy with this program... pity it's a bit expensive, though :wink: !
Cheers,
J-P.
paddler
a few images.
Unread postby paddler » 26.05.2008 23:53
Those are beautiful images. Do you use a focusing rail or the lens focus ring? What sort of flash do you use and at what setting?
JPS
Unread postby JPS » 27.05.2008 09:41
Hi ! Thanks for commenting...
I tried to use both systems -locked focus and moving camera on rail vs camera still and rotating the focus ring- and choose to keep the camera on tripod and rotate the focus ring !
For the iris, the lighting was a 100W Elinchrom into a 24x24" (60x60 cm.) softbox on the left, a white foamcore reflector on the right and a ringflash -at minimum power- on the lens. The background is a piece of black velvet.
For the lathe, the lighting was simply a 100W Elinchrom into a 24x24" (60x60 cm.) softbox, at 45 degrees to the ceiling (to avoid parasitic shadows). Camera was a Nikon D200 with a Tamron SP90.
Hope this helps ?
Cheers,
J-P.
paddler
Unread postby paddler » 27.05.2008 10:10
Excellent. Thank you for the information J-P, I appreciate it. I'm just getting started myself and find I'm having a great deal of trouble acclimating to the fine adjustments needed to the focus ring on a lens to get the necessary slices in any kind of even distribution of focus but the issue of perspective with a focus ring is one to consider also. I'm sure loving playing with the possibilities of this though.
Your images are fabulous.
JPS
Unread postby JPS » 27.05.2008 10:35
Hi ! Not to worry too much... if you're shooting at f/8 (or so), rotating the focussing ring one millimeter at a time will give you more than needed security to get your entire depth of field covered sharply !
Cheers,
J-P.
okie
JPS' flower shot with strobe
Unread postby okie » 01.06.2008 00:12
Very impressive flower shots, JPS. Outstanding "glow" to the petals. Is there much post-processing involved with these images, or is it "straight from the camera?" I've been doing similar work... but outside. Even at the crack of dawn there's often a breeze, as gentle as it may be.
One tip worth sharing with flower shots: find a "Mister" type of pump-up canister and give the petals and greens a very light touch of water droplets - similar in size (tiny) to morning dew. Water "sprayers" per se, do not work well, it is the misting type that delivers top-notch results. (I have one in my kitchen used for bread baking).
An aside: when have you found it "best" to apply sharpening? "By the rules" we always do it last in PhotoShop... but when using Helicon Focus software I haven't arrived at a definitive answer - sharpen first, then run through HF... or sharpen the outputted HF image. (In all instances my Canon 5D camera is adjusted to apply zero "in-camera" sharpening.
JPS
Re: JPS' flower shot with strobe
Unread postby JPS » 02.06.2008 09:33
okie wrote:Very impressive flower shots, JPS. Outstanding "glow" to the petals. Is there much post-processing involved with these images, or is it "straight from the camera?" I've been doing similar work... but outside. Even at the crack of dawn there's often a breeze, as gentle as it may be.
Hi and thanks for commenting !
As for applying some "dew" on the petals, i didn't think of it, although it's a trick i often use...
Now, about the sharpening, as long as i remember, i loaded the original RAW images into Helicon Focus, so no post-processing AT ALL was applied before... and i also allways use the "zero in-camera" settings !
Of course, the image rendered by Helicon Focus has been post-processed as usual, with a final sharpening, then resizing for Web, and finally one more slight sharpening !
Cheers,
J-P.
Guest
Unread postby Guest » 03.06.2008 20:57
[quote="JPS
J-P.[/quote]
My experience has been similar, that sharpening and then a bit more seems to produce excellent imagery. Frankly, amazes me how much post-processing sharpening the Helicon image can handle, far more than a file directly out of the camera.
An aside: seeing your strobe images inspired me to try the same instead of always working outdoors (USA, Florida, where it comfortable to work outside year-round). Literally even cut the iris flower I initially photographed (in layers) outdoors, then brought it into the studio: a 24"x36" softbox and a reflector on the opposite side, but without any ring flash from the camera. Remarkable results! Particularly when applying a black backdrop... sample about a dozen different backgrounds and came back to "black is best." And what a delight to shoot indoors without wind or light-change factors... I thought I was in heaven. (Camera is directly tied to a computer using Breeze's DSLR Remote Pro software - instant gratification!).
Your ideas and input was very helpful, J-P. Thank you.
JPS
Unread postby JPS » 04.06.2008 09:23
Hi "guest" !
Pleased to know that you found another way of shooting flowers... Right: it's not as "fair" as shooting them "in the wild", but -at least here in Switzerland- so much more practical :wink: !
Let see YOUR results, then...
Cheers,
J-P.
peteschick
focus ring
Unread postby peteschick » 13.02.2009 23:13
Can someone tell me what a focus ring is?
Could I use it on a Canon xsi 450D?
Guest
Re: focus ring
Unread postby Guest » 14.02.2009 08:18
peteschick wrote:Can someone tell me what a focus ring is?
Maybe I misspelled it !?! The "focus ring" that I refer to is the FOCUSSING RING on the lens, that allow you -mainly on an SLR/DSLR camera- to focus on your subject: I guess one might also call it DISTANCE RING !?!
Got it ?
Cheers,
J-P.
Users browsing this forum: No registered users and 6 guests
