Lock proportions
Ariel
Lock proportions
Unread postby Ariel » 15.06.2007 02:39
Sometimes you do a custom sized crop and like it just so, but then you notice that the pixel amount is not what you want it. I suggest having a lock/unlock button or icon next to the area with the pixel numbers so if you have a good proportion and location already for the crop, you can lock that and then adjust the pixel amount.
Unread postby Dan Kozub » 15.06.2007 22:25
You mean that you resize the frame with "Keep aspect ratio" off , then click the button and these proportions are saved as a new proportions?
Maybe add one more radio button with the actual frame proportions?
Ariel
Unread postby Ariel » 16.06.2007 00:55
What I mean is that after you get a crop that looks the way you want (meaning the correct part of the picture will be cropped), yet you notice that the amount of pixels the image will be saved at is not the pixel number you want, you should be able to lock the proportions and change the pixel numbers without having the set crop change.
