Does the HDR in Helicon Filter align like Focus?
Ariel
Unread postby Ariel » 12.03.2007 03:13
Does the HDR in Helicon Filter rotate and align images just in case the pictures are not all aligned exactly the same way, or can it align the images? Because the images after doing the HDR seem a little soft. BTW: The contrast and brightness after doing an hdr is kind of low. You should be able to open an HDR dialog, select all the images to combine, and have it balance all the colors so the brightness is like a "standard" exposure so all the areas have relative proper exposure, making sure to, while mixing the areas of different brightness, keep the contrast reasonable.
