Straight line for brushes
Ariel
Unread postby Ariel » 16.02.2007 07:47
I have an idea which would let one move a brush in a straight line if wanted.
Have an angle of brush box which people can type in an angle that the brush would go in. And when they hold down a letter in the keyboard or press a button next to that angle box, the brush would only go in that direction.
Maybe also make it so if set to go in a straight line, the angle of the brush can be changed by scrolling with the mouse wheel.
Ariel
Unread postby Ariel » 16.02.2007 07:51
And how about a similar thing for the angle of brush action for the distort and delete scratches brush?
Unread postby Dan Kozub » 16.02.2007 10:19
You can draw a straight line by clicking with shift pressed. The program will draw a line between current and previous point.
Angle of the brush: you can change this angle by Ctrl-Mouse Wheel
Ariel
Unread postby Ariel » 16.02.2007 21:01
Are these hints mentioned in the program? An intuitive program would.
Ariel
Unread postby Ariel » 16.02.2007 21:03
If you hold shift with the first click, the brush doesn't work in the first clicked spot.
Ariel
Unread postby Ariel » 16.02.2007 22:33
When you move the mouse over something or select an option, a helpful line of information or a useful hint should show up at the bottom of the screen. I understand that this already happens for some things, but if you are using a brush, or if you move the mouse over a brush type, tab, or icon, helpful information should always show up.
Unread postby Dan Kozub » 17.02.2007 00:08
we avoid such a help because tooltips is very annoying in some cases. But you are right, the message in the status bar would be very helpful
Ariel
Unread postby Ariel » 17.02.2007 00:16
It doesn't have to show up next to the mouse. I REALLY like the way Inkscape does it.
I suggest downloading Inkscape and moving the mouse over different things and selecting different things. It is really helpful and not annoying the way they give hints and the hints they give. And they also include lots of times in the hints a quick keyboard shortcut, which is nice.
