More zoom choices
Ariel
More zoom choices
Unread postby Ariel » 13.02.2007 06:41
I don't always want to zoom just at 50%, 100%, and 200% (and the other values above and below). I sometimes want to zoom to 74%, or 156%, for example. The slider should have all the zoom choices, like in Picasa.
Unread postby Dan Kozub » 13.02.2007 09:48
It is easy to implement, but it is hard to select exactly 50% or 100% in this case. with 105% you loose quailiy of the preview and this is not good.
ariel l
Unread postby ariel l » 13.02.2007 20:05
There could also be predefined variables, but there should also be a slider.
Ariel
Unread postby Ariel » 16.02.2007 07:34
It is important that one can slide to any zoom and still choose some common values, including a box where you can type in the zoom you want. Anyhow, 105% zoom won't show noticeable quality decrease from 100%.
And people should be able to zoom (in) on the resize tab (like you could zoom the page or scroll to view different parts of the image, but the crop box keeps on the area you put it on) so they can be more sure that the crop is going exactly where they want.
