Color map for Colors tab
Ariel
Unread postby Ariel » 13.02.2007 06:28
You know how there are edit maps for noise reduction, aberrations, and sharpening? There should also be an edit map for colors. Because when I use the equalizers, I want to be sure that I'm just changing what I want to change, and nothing else. Maybe also you could zoom in on the color tab? It's pretty annoying how you can't zoom into an area in that tab (the magnification glass doesn't suffice).
Ariel
Unread postby Ariel » 13.02.2007 06:31
P.S. It would be nice if the markers on the equalizers would move when using the magnification glass and if there would be a cross or target thing over middle of the glass.
Unread postby Dan Kozub » 13.02.2007 09:43
OK. good points.
