I discover helicon ; my suggestions
IIII
Unread postby IIII » 11.12.2005 00:21
I discover helicon ; my suggestions (excuse my english ... my 'frenchglish' ...) :
I need often the use of the zooming, to adjust the WB and the luminance. It is very hard to do this in the original view ...
I find that you need to incorporate a real system to control the WB, with temperature, and a zooming for point the gray scale. This the major limitation.
The adjustement of the colour is very not fine.
The rotation is not easy ; the use of a grid would be useful, and the number of degrees too.
I don't know if it is possible or not ; but some software propose the possibility to recover informations in highlights, and it is very useful.
I discover today helicon with the demo, but the problem of the adjustement of the WB is critical for me ... so I won't buy this version. I hope that the 4.0 will be the good one for me.
Gratulations et good work.
Max.
IIII
Unread postby IIII » 11.12.2005 00:26
I forgot : I need often in the EXIF informations the lens used ...
IIII
Unread postby IIII » 11.12.2005 18:58
AND there is no way to undo an action ; just the 'Reject' but it all the settings of the section :roll:
This is a major problem too
IIII
Unread postby IIII » 11.12.2005 23:47
I have an instability in Helicon ... :?:
Not always, but the soft is frozen when I open images... for the moment 1 every 5 times.
This is known ? :?:
IIII
Unread postby IIII » 12.12.2005 00:45
I have used the soft one day more, et I begin to appreciate it a lot.
thanks for this
I will certainly buy this one, actually.
:wink:
Unread postby Dan Kozub » 12.12.2005 21:05
Thanks for the comments :)
I will be waiting for your comments to the version 4.0 which will come soon
IIII
Unread postby IIII » 12.12.2005 21:32
:o no problem
Is there a way to receive a mail when the 4.0 will be on line ? :?:
Thanks a lot. :)
Unread postby Dan Kozub » 12.12.2005 21:46
The best way to be notified is to subscribe to newslist:
http://helicon.com.ua/lists/
IIII
Unread postby IIII » 12.12.2005 23:05
It's done! thanks.
The plugin Ptlens is not compatible with helicon filter ...
Even if the correction of the distorsion is possible with helicon, ptlens has a very precious list of presets for each lens ... it is so precalibrate and automatic ...
http://epaperpress.com/ptlens/
Unread postby Dan Kozub » 12.12.2005 23:17
Yep, we have problems with some PS plugins. It is difficult to make a compatible host for PS plugins but we are working on it.
IIII
Unread postby IIII » 12.12.2005 23:33
:P ok
good work.
I will enjoy test the 4.0 when released.
:wink:
IIII
Unread postby IIII » 13.12.2005 11:54
I edit my post:
I said that the recover of highlights in Helicon Filter was not as good as other soft.
But it is wrong, I was wrong!
Helicon Filter recovers the highlights! This error comes from the contrast of highlights, that was high.
Just the change of the contrast in clarity is for the moment not easy with this version (3), and I hope that the next version (4.0) will resolve this problem.
Unread postby Dan Kozub » 13.12.2005 20:41
I hope you will like the new look of v.4.0.
I would appreciate if you could send me a couple of sampes with problem highlights and the best result that you got from other program.
You can upload samples to our ftp server:
ftp://web10f6:123456@helicon.com.ua
regards,
Danylo
IIII
Unread postby IIII » 13.12.2005 22:11
post edited
IIII
Unread postby IIII » 14.12.2005 20:39
I have edited my post :)
