Wish list for Helicon Filter v.5
tombell
Crop size
Unread postby tombell » 17.02.2009 14:32
I would like a crop size of 1680 x 1050 added to sizes in New size.
Kgeo
Retouching Brush shape
Unread postby Kgeo » 09.04.2009 16:29
it would be very helpful, to get some other shapes for retouching brush, e.g. quadrat (with small quadrat inside), triangle and ellipse.
Kgeo
_______________________________________
PC: SCALEO Hi 2553 (Quad core CPU Q6600)
Graphics: nVidia GeForce 8600GS 512 MB
OS: Vista Home Premium, SP2
step
Text&Frame
Unread postby step » 12.02.2010 18:52
Could you move this option (add text, time stamp, etc.)back in the version 5? Thanks
Re: Wish list for Helicon Filter v.5
Unread postby Stas Yatsenko » 15.02.2010 15:47
Yes, we surely will do this.
GoldWing
Unread postby GoldWing » 22.02.2010 02:45
I really wish this would be mac compatible without having to use parallels or similar to get it to run on mac. Please,Please. I have left windows and am now a mac user. I have tried Aperture, Lightroom, Elements8. After using Helicon for years, I just can't get my head around why these other programs are used by anyone!! Helicon Filter does everything I need to do, plus more that I may never do, and does it all so easily. I really don't want to use Parallels, but I will if I absolutely have to. It is my dream to use Helicon on a computer that isn't always screwing up. Sorry Windows users, but I just can't live in that camp anymore.
Unread postby Stas Yatsenko » 23.02.2010 16:33
We do plan to make a mac version but it would take some months.
wtpc48
Unread postby wtpc48 » 06.03.2010 12:50
thanks for the great program...the onlt y thing i do miss from the 4.93 is the watermark (TEXT) can that be done in the next version??
thanks again and keep up with the good work.
Unread postby Stas Yatsenko » 09.03.2010 15:17
Please note that this is a beta version. We will add many more functions like adding text or replacing colors till the release. You are welcome to test this version and give us your comments and suggestions.
Daniel
Unread postby Daniel » 27.03.2010 19:38
Hi there,
I use your software in version 4.X for a while now and I'm very happy with it.
I just downloaded the latest Beta 5. It's extremely slow ! That's all I can say for the moment. Slow in navigation (try to click on a folder that contains 600 JPG of 5 to 9 Mb) and very slow to display RAW pictures.
I did not start to work with it at the moment but I'm so badly surprized by the delays that I'll certainly wait for improvement before I use it again.
Back to 4x.
I'm sure you can do a lot better.
Cheers
dan
Unread postby Stas Yatsenko » 29.03.2010 21:55
I hope you will keep an eye on our new versions. We already fixed the problem with big folders and we are working on optimizing the other aspects of the program. You are welcome to install both version and use both of them.
Daniel
Unread postby Daniel » 31.03.2010 12:28
Stas Yatsenko wrote:I hope you will keep an eye on our new versions. We already fixed the problem with big folders and we are working on optimizing the other aspects of the program. You are welcome to install both version and use both of them.
Hi Stas,
Only good news then!
I'll check that as soon as possible. When do you plan to release the next beta?
Cheers
Dan
Unread postby Stas Yatsenko » 01.04.2010 12:25
We plan the release in the coming week, till 12 th of April.
lutz
Unread postby lutz » 10.04.2010 21:01
I believe Helicon Filter 5 could use an easier method of straightening images. My favorite method is usually to "draw" a horizon line into the image and have the editor rotate the image accordingly (i.e. "drawing" a line along edges of an object on the image which should either become horizontal or vertical in the corrected image). Also an overlayed grid just for rotating would be helpful.
Unread postby Stas Yatsenko » 13.04.2010 14:41
You can use this method too. If you press Ctrl and draw a line on Resize tab it will work the same way. We will make this functonality more evident.
exponator
Unread postby exponator » 04.05.2010 22:07
I have been using with much pleasure version 4.8 and since a few weeks I am using Version 5.0 beta.
In both versions I strongly miss the possibility to select a color for the lines/cross/etc in "Resize". Now it is standard only in green and when resizing pictures taken in nature (which often at least are partly green!), I can only find the corners and the center cross with much difficulty. So it would be very helpful if I can choose the color of the lines/cross/etc. I can image there are several other types and colors of the pictures where it will be very helpful if you choose a (contrasting) color for the lines/cross/etc yourself.
Succes with further improvements of version 5.
Exponator
