Helicon Focus: Tool to make pre-defined scale measurements
Ariel
Unread postby Ariel » 20.12.2007 05:48
See this thread: http://forum.helicon.com.ua/viewtopic.php?p=3158#3158
Perhaps there should be a feature in Helicon Focus which allows users to make a set of pre-defined scales (to mark the actual size of objects in microscope photography) that a user can easily select from a customized list. Additionally, the existing scale feature should allow the user to add a caption to it, such as 1mm, to identify actual subject size.
Guest
Re: Helicon Focus: Tool to make pre-defined scale measuremen
Unread postby Guest » 20.12.2007 06:39
Ariel wrote:See this thread: http://forum.helicon.com.ua/viewtopic.php?p=3158#3158
Perhaps there should be a feature in Helicon Focus which allows users to make a set of pre-defined scales...
A tool that would allow calibration relative to predefined magnification sets would go a long way towards making HF a tool for scientific study and illustration. Automontage has this function, along with the ability to take measurements, both of which are a large part of insect taxonomic studies.
Unread postby Dan Kozub » 21.12.2007 12:43
This is a good idea. How do you see calibration process? As I understand you need to enter magnification for each image so the program can calculate everything else.
ndemik
Unread postby ndemik » 22.12.2007 02:43
Attached is a quick set of screen shots I took from Automontage showing how callibrations are made...
how_to_calibrate.zip
(173.32 KiB) Downloaded 488 times
Unread postby Dan Kozub » 25.12.2007 16:40
Thanks for the presentation! : ) We will think how to implement this.
