4.71: brightness auto detect- set local contrast to 100!
guest
Unread postby guest » 08.09.2007 12:46
a big bug in the 4.71 version!
If you choose the autodetect-option in the brigthness-tab, the local contrast are set to 100!
Howard R
4.71 Contrast Problem
Unread postby Howard R » 09.09.2007 16:19
I experienced the same problem
kees mazee
autodetect failure
Unread postby kees mazee » 12.09.2007 01:03
autodetect option also fails at this end -slider jumps to 100%
christoph st-v
autodetect
Unread postby christoph st-v » 18.09.2007 10:00
I`ve the same experience. The slider walks to 100 % and the result is no good.
alesk
4.71 problem
Unread postby alesk » 20.09.2007 17:55
Same with me. On the earlier version local contrast only went up to 3, not 100!
So far no responses to this inquiry. Is someone from HF working on this?
AE
lutz
Unread postby lutz » 20.09.2007 20:07
Dan,
who is the one surveying the forum, had announced that he will be away for two weeks. He should be back soon. Then the reactions to problems are usually swift.
(Strangely, I do not observe the problem myself, or I am ignorant to it.)
Well, forget about the last sentence. Local contrast is really screwed in version 4.71
Unread postby Dan Kozub » 25.09.2007 16:34
Sorry, will be fixed ASAP!
Users browsing this forum: No registered users and 6 guests
