Can't use DCRaw
firexball
Can't use DCRaw
Unread postby firexball » 26.08.2007 00:23
I have a little Problem with the Preferences of Helicon Filter. I can't use DCRaw anymore!
If I switch the option in the Preferences "use DCRaw" and choose a RAW-file the dialoge for the "normal" RAW development appears!
I have really tried everything (including reboot and new installation). I am using the 4.70.4 Version.
Please help!
Greetings firexball
firexball
Problem is solved
Unread postby firexball » 26.08.2007 10:45
I have solved the Problem on my own.
I just have to delete the file "temporary_hnf_image.tmp" in the "\Helicon\Filter4" directory!
Maybe it would be good, if Helicon Filter deletes this file bevor every DCRaw call?
Unread postby Dan Kozub » 28.08.2007 21:35
Thanks for the tip!
firexball
Unread postby firexball » 04.09.2007 18:31
Hello!
After ongoing problems with that, I investigated a little deeper... and found out, that the real problem was, that the original RAW file was write protected! So HF copies the RAW file (with its attributes) and after the conversion, HF can't delete it. At the next call of dcraw, HF wants to copy the new RAW file and fails... So HF should only change the attributes of the RAW file after copying! :)
Unread postby Dan Kozub » 05.09.2007 16:21
ok, we will fix this too
