How to retouch C-mode file with elements of B-mode file
hago
Unread postby hago » 04.07.2013 16:54
I stacked 134 files in C-mode and in B-mode.
Now I would like to retouch the C-mode result with parts of the B-mode result.
How could I do that?
Regards, Hago
Re: How to retouch C-mode file with elements of B-mode file
Unread postby Stas Yatsenko » 05.07.2013 21:12
Hago,
It is not possible now, we plan to implement this feature in the coming versions.
Right now you can save both results, then stack them, then go to retouching and use the brush to define which result (layer) should be used.
hago
Unread postby hago » 05.07.2013 21:51
Thank you,
that is a good idea.
I'll try.
Hago
