Helicon Filter 5.2.4 Problem
jpmccormac
Unread postby jpmccormac » 19.06.2013 01:03
I just downloaded this new version of Helicon Filter: Version: 5.2.4 - Date: 18.06.2013. The installer removed the old program (5.2.2), but when the new program loads it freezes and locks up my Windows 7 Home Premium PC. At this point I can't even get to my desktop and must use Windows Task Manager to end the process. Anyone had this problem?
June 19, 2013. Edit/Update. Removed HF 5.2.4 - again - with Windows uninstaller and cleaned up the registry with CCleaner. Reinstalled HF 5.2.4. Problem remains - Program locks up after the splash screen at startup.
jpmccormac
Re: Helicon Filter 5.2.4 Problem
Unread postby jpmccormac » 20.06.2013 15:00
When HF 5.2.4 tries to start up and freezes, the Windows Task Manager shows that CPU usage jumps to 99%!
Unread postby Stas Yatsenko » 21.06.2013 11:07
We have similar complaint about Helicon Focus and are now actively searching for this bug. What kind of processor do you have? AMD or Intel?
jpmccormac
Unread postby jpmccormac » 21.06.2013 12:49
AMD Athlon II X4 630 Processor 2.80 GHz. 4 GB Ram. 64 -bit OS.
Thanks for the help, Stas.
Unread postby Stas Yatsenko » 25.06.2013 11:19
I think we located the bug. We have sent you the link to fixed library as a private message.
PM:
John,
I think we found the bug. Please download
http://downloads.heliconfilter.com/hlib_safe_sse.dll
then rename it to hlib.dll and replace hlib.dll near HeliconFilter.exe
If this will now work, try to replace hlib.dll with this one:
http://downloads.heliconfilter.com/hlib_limited_sse.dll
Please let us know if this helps via support@heliconsoft.com
