Problem with command line parameters
schmidt_s
Unread postby schmidt_s » 28.05.2013 09:57
When running Helicon Focus from the command line, I can't get it to save the stacking result into the folder that is given as a parameter. For example, the following command saves into the default "Focused" subfolder using default names, but not in "D:\Pictures". Any suggestions on how to get this to work?
Code: Select all
"C:\Program Files (x86)\Helicon Software\Helicon Focus\HeliconFocus.exe" -silent -mp:3 -j:10 D:\Pictures\CCDB_Images\A01 -save:D:\Pictures\result.jpg
Cheers,
Stefan
Re: Problem with command line parameters
Unread postby Stas Yatsenko » 29.05.2013 11:44
We already fixed this bug, please install the latest version from our server.
