Support for Fujifilm X-pro 1
Caderyn
Unread postby Caderyn » 23.07.2012 14:51
Hey,
Just trying to convert Fujifilm x-pro 1 RAF files into tiffs using dcraw (updated the underlying files) and I am getting roughly half of the resolution of the raw files as tiffs.
I should say also that I have purchased the full version.
Re: Support for Fujifilm X-pro 1
Unread postby Stas Yatsenko » 23.07.2012 22:22
We need to test your files in our environment. Can you please upload them to our ftp server as described at http://www.heliconsoft.com/ftp.html
Caderyn
Unread postby Caderyn » 24.07.2012 00:29
Hey,
Uploading the files now on to the ftp in the folder 'Caderyn".
Note also that I had to install the latest version of dcraw over the top in order to support the x-pro 1.
Cheers,
Caderyn
Unread postby Caderyn » 24.07.2012 00:33
Hey,
I have uploaded the files to the ftp.
Note I had to use the latest version of dcraw to get fujifilm x-pro 1 compatibility.
Cheers,
Caderyn
Unread postby Caderyn » 24.07.2012 12:56
Hey,
I have been looking through the exif data for the raf files and it seems like helicon is picking up the thumbnail size maybe and not the raw pixel dimensions.
Hope this helps and I hope you are able to solve the problem!
Unread postby Stas Yatsenko » 25.07.2012 14:24
Thanks for the test files. Yes, Exif information shows wrong dimentions bug the file itself is opened in full resolution (16Mpx). The problem is that we use two different modules to get exif data and to develop RAW files. We know about this bug and we already have plans for a solution.
Caderyn
Unread postby Caderyn » 26.07.2012 04:12
Thanks for the reply.
Is the fix likely to make it into the next update to Helicon Filter?
Are there any workarounds in the meantime?
Unread postby Stas Yatsenko » 27.07.2012 14:35
I am not sure it will be in the next update but in a few weeks this will be fixed. Please note that only information is not correct, the file itself is opened correctly.
Caderyn
Unread postby Caderyn » 28.07.2012 04:57
Thanks.
Yeah I understand the file is being opened correctly.
I am going to hold off converting my raw images as currently when I convert with helicon filter and import into lightroom the information displayed is incorrect (resolution).
I would rather have everything perfect ;)
Unread postby Stas Yatsenko » 31.07.2012 12:57
I hope we will fix this soon.
Caderyn
Unread postby Caderyn » 16.08.2012 08:30
Hey,
Any updates in terms of progress in fixing this issue?
A lot of x-pro 1 users are looking for alternative raw conversion (adobe's raw engine results in artifacts) so with multithreaded dcraw in helicon filter I think you have a winner.
Happy to provide free publicity via twitter etc once it is fixed.
Unread postby Stas Yatsenko » 17.08.2012 11:46
We will publish a new version of Helicon Filter and Helicon Focus with new DCRAW version.
Caderyn
Unread postby Caderyn » 06.09.2012 11:15
Hey,
I noticed that a new version 5.0.28 is out.
I haven't had any luck in successfully converting the x-pro 1 raw files to tiff (without a loss in resolution).
Cheers,
C
Unread postby Stas Yatsenko » 07.09.2012 10:04
Try to use different RAW converter in the Preferences of Helicon Filter. If this does not help please send your RAW file to our ftp server as described at http://www.heliconsoft.com/ftp.html
Caderyn
Unread postby Caderyn » 07.09.2012 16:06
Hey,
I don't know how I made it work, but switching between adobe converter and back to dcraw seemed to help.
I now get full resolution tifs.
Thanks for your help!
C
