Did I wast me money??
mitchell
Unread postby mitchell » 01.01.2012 17:55
I bought The 64 bit version and I'm not having any luck with it OR the Helicon remote. Im running windows 7 64bit ultimate with 8gig ram.
First I tried the remote...I set my camera on my table with a pop can in front ...went to set the focus point and I keep getting errors saying the program detected error while communicating with camera report a bug if this error persists the program may not function properly until you restart the camera. I am using a Nikon D300 with firmware 1.10... is it the software? am I doing something wrong?
SO then I decided to play with Helicon Focus
I tried it for the first time yesterday with a series of 6 D300 RAW images. The first attempt it just locked up after about 30 seconds. I had to control alt delete to shut it down. Second attempt went a little farther then crashed...AND because I didn't right down what the error said I'm running the same 6 images now...first attempt after about 10 seconds it said Helicon stopped working and when I pressed OK it shut down. and this is my second attempt...AND its HUNG at the bottom it says Reading Source Image...another control alt delete required to force it to shut down.
I'm NOT having any problems focus stacking these same images in CS5. This is getting VERY aggravating
Re: Did I wast me money??
Unread postby Stas Yatsenko » 03.01.2012 11:51
Sorry to hear you have troubles with our software. To locate the problem, we need more information from you, it is better if you contact us via support@heliconsoft.com
One of our users experienced system crash when running Helicon Focus. It turned out that his CPU was clog up with dust and CPU overheated when Helicon Focus used all the computer power. So please do not jump to conclusions.
Please contact us via email and we will send you test version of the software to identify the problem.
mitchell
Unread postby mitchell » 03.01.2012 17:59
great. Got your email. I will clean out my cpu as well.
mitchell
Unread postby mitchell » 03.01.2012 20:39
Stas
I cleaned out my CPU...wasn't really dirty but I gave it a quick blast of air.
I downloaded the new version and ran the same 6 files. It gave me an error after about 20 seconds and prompted me to email the results Which I did. BUT after it emailed the results it continued to process the 6 files into a perfect stack. ???
so?? I guess its working? but why the error and crash at the beginning??
Unread postby Stas Yatsenko » 04.01.2012 11:45
Thanks for the help with this bug. The log file showed us where the problem is. We will prepare newer version for you to make sure we fixed the bug. In the meantime, please use debug version (without sending bug reports).
mitchell
Unread postby mitchell » 05.01.2012 22:22
Hi there. I can no longer use the debug version. It just keeps crashing. I'll just await the new version you are preparing for me.
Unread postby Stas Yatsenko » 06.01.2012 15:06
We will send you newer version via email.
mitchell
Unread postby mitchell » 06.01.2012 20:28
New version is installed and 2 6 image stacks have been processed with no errors. Looks great so far. Thanks.
Unread postby Stas Yatsenko » 09.01.2012 10:39
Great. Thanks for your patience and assistance in finding the bug.
