Helicon Print 1.0.4
73QmXXPU
Helicon Print 1.0.4
Unread postby 73QmXXPU » 21.07.2011 12:42
I am not so happy that Helicon Print 1.0.4 took over the function as default image editor.
Whenever I open an image it's Helicon Print which acts as a photoviewer.
Changing the editor- choice does not help, it helps only once, afterthem it's again Helicon Print which opens my images.
I have nothing against Helicon Print but that's not THE program one would see as his photoeditor, isn't it?
Even clicking on the Image and Properties and changing the editors choice does not work because the V (or okay indication) can not be changed while it is in gray and in this way inactive.
Will I have to uninstall allof my Helicon programs for this inconvenient?
Johan Vanhauwaert
Re: Helicon Print 1.0.4
Unread postby Stas Yatsenko » 22.07.2011 18:48
Johan,
Helicon Print never tries to register itself as default program. Most probably you right clicked the files and said to open it with Helicon Print and the check box "Always use this program ..." was checked. This is default Windows behaviour. Do this again but choose the program you like.
