Canon S95 RAW File Support
jpmccormac
Unread postby jpmccormac » 19.04.2011 01:26
In HF ver. 5.0.15 there appears to be no support for the Canon S95 RAW file. I've tried all of the available RAW converters in the Preferences. Anyone having the same problem or know of a solution? Thanks.
Re: Canon S95 RAW File Support
Unread postby Stas Yatsenko » 19.04.2011 10:38
Please upload one image to our ftp server (as described at http://www.heliconsoft.com/ftp.html). We will test it.
jpmccormac
Unread postby jpmccormac » 19.04.2011 14:37
Stas, I uploaded the Canon S95 RAW file titled RAW IMG_0330.CR2 to the FTP root directory. Since I shot the image as RAW+JPG I also uploaded the JPG image - RAW_IMG_0330.JPG also so you can see it. When I open the RAW image in HF 5.0.15 it has a very deep purple tone.
As always, thanks for your help.
John McCormack
Unread postby Stas Yatsenko » 20.04.2011 10:57
Thanks. We will add support for your files.
jpmccormac
Re: Canon S95 RAW - Working Now. Weird
Unread postby jpmccormac » 09.05.2011 02:25
I was working with some S95 RAW files today and thought I'd try again to open one in Helicon 5.0.15. It turns out that Helicon read the file fine with DCRAW converter, though I had made no changes to the options folder. Hmmm? Was there an update I'm not aware of?
Unread postby Stas Yatsenko » 10.05.2011 11:49
Most probably the program offered you to use different RAW converter it fails to open RAW file with the default one. You can experiment by resetting options to default values.
jpmccormac
Unread postby jpmccormac » 11.05.2011 02:19
Stas Yatsenko wrote:Most probably the program offered you to use different RAW converter it fails to open RAW file with the default one. You can experiment by resetting options to default values.
Helicon didn't "fail to open the RAW file." It opened the file but the colors are all way off and almost completely dark. Anyway, I will wait for an update that includes the Canon S95 RAW files. Thanks.
Unread postby Stas Yatsenko » 12.05.2011 11:53
We sent you a new beta version of Helicon Focus with an updated Canon SDK, you are welcome to test it. If this version of Helicon Focus works, then the new version of the Helicon Filter will work properly too.
