Bug and question
Lümmel
Bug and question
Unread postby Lümmel » 11.03.2011 11:41
Dear all,
I guess I found a bug in Helicon Filter 5.0.15. When I change the method of RAW-conversion in the preferences e.g. from DNG to the included converter, I have to reset the whole tab to revert these changes or to use a third method. Even if I click "save settings" the settings get lost.
Concerning my question: Is it possible to use the B&W-presets from HF 4.93 like Agfapan etc. in HF 5 and how?
Regards,
Lümmel
Guest
Re: Bug and question
Unread postby Guest » 11.03.2011 19:07
I too would like to have the B&W presets added to Helicon Filter 5. I really miss that feature.
Howard
Lümmel
Unread postby Lümmel » 12.03.2011 00:04
And another bug: The print dialogue's preview of the image doesn't fit with the real output of the printer. If I select e.g. "fill page" then the picture is correctly printed, but the preview shows only a part of the picture (and yes, I chose the right magnification). This occurs if I choose the highest printer resolution (in my case 730 dpi), not with the standard resolution.
Regards,
Lümmel
P.S.: Still the best program on the market to me, despite minor bugs that hopefully can be corrected ;-)
Unread postby Stas Yatsenko » 14.03.2011 11:34
Lümmel wrote:Is it possible to use the B&W-presets from HF 4.93 like Agfapan etc. in HF 5 and how?
Sorry, presets are not compatible. The only way is to draw the same curve on Sensitivity equalizer as it was in 4.x version.
Unread postby Stas Yatsenko » 14.03.2011 11:36
Lümmel wrote:And another bug: The print dialogue's preview of the image doesn't fit with the real output of the printer. If I select e.g. "fill page" then the picture is correctly printed, but the preview shows only a part of the picture (and yes, I chose the right magnification). This occurs if I choose the highest printer resolution (in my case 730 dpi), not with the standard resolution.
Thanks, this will be fixed.
