Helicon Filter beta and CS5
kabkos
Unread postby kabkos » 27.06.2010 18:24
When I use the Helicon Filter beta plug-in with CS5 the pictures look like the brightness/exposure has been pushed to the extreme. I tried a picture using each tab seperately (did a color adjustment then saved picture, opened a new picture and just did a noise adjustment, etc, a new picture testing only one tab at a time). The color adjustment worked properly, but all of the other tests had the picture going back into CS5 with the picture over exposed or blown out. I'll play again with the beta version and see if there is some gamma adjustment preference that is causing this.
karl
Re: Helicon Filter beta and CS5
Unread postby Stas Yatsenko » 29.06.2010 13:14
Karl,
Please reset settings on the brighness tab to default values and see if this helps. And make sure you are using the latest version of Helicon Filter which is 5.0.9
