Helicon Filter 5 Plugin Malfunction
Willem de Vlaming
Unread postby Willem de Vlaming » 27.06.2010 11:11
Helicon 5.0 doesn't have access to my plugins
When I try to run BW styler 1.03 I get an error message
"Access violation in PluginExecute.dll
read of adress 00000008"
What do I need to do to get the plug ins running in Helicon 5.0 They all worked well in 4.93
Thanks!
Re: Helicon Filter 5 Plugin Malfunction
Unread postby Stas Yatsenko » 29.06.2010 13:12
Please give us the names of plugins you are using and we will test them for compatibility.
Unread postby Stas Yatsenko » 29.06.2010 14:27
We installed the plugin into the latest 5.0.9 version and it works fine. The plugin installer detected 4.x version of Helicon Filter so we had to copy *.8bf file into plugins folder of 5.x version.
Willem de Vlaming
Unread postby Willem de Vlaming » 15.08.2010 10:05
I'm still having problems with running the plugins in Helicon 5.0 no problems with running them in 4.9 After reinstalling the plugins sometimes work for a short while in 5.0 and then it returns to the same error... So there is compatibility, but not a happy marriage :-)
Now I do most of my editing in 5.0 and run the plugins through 4.9
Unread postby Stas Yatsenko » 17.08.2010 12:49
Thanks for reporting this bug. We checked again and were able to reproduce it. So we add it to our our to do list for the next version.
Unread postby Stas Yatsenko » 18.08.2010 09:13
I would appreciate if you test the bug fix. Please replace \library\PluginExecute.dll with this file:
http://downloads.heliconfilter.com/PluginExecute.dll
Willem de Vlaming
Unread postby Willem de Vlaming » 18.08.2010 10:23
Sorry still the same error
access violation at address 00393279 in module pluginexecute.dll Read of addres 00000008
Unread postby Stas Yatsenko » 18.08.2010 11:40
Strange, we had an error only when calling this plugin after applying one of our filters. This bug is fixed and plugin works fine with our development version. We will prepare a test installation for you and send you a link.
Willem de Vlaming
Unread postby Willem de Vlaming » 18.08.2010 15:35
OK thanks!
