Helicon under XP; User rights
Guest
Unread postby Guest » 22.05.2004 17:13
Hi
i tried to use Helicon on my PC. I always install soft as admin and run it as restricted user.
Helicon cannot run in this mode, since it wants to write to HKLM/helicon..../..
So, when i start it as restricted user, i cannot load any file.
The only possibility i found is, to give change Rights to this HKLM Key. But this it not a good solution.
markus
Unread postby Dan Kozub » 23.05.2004 09:30
Thanks for this comment. We will check this.
JF
Unread postby JF » 29.07.2005 10:42
The latest version (3.10) gives an bad error message upon start when running with restricted rights...
Guest
Unread postby Guest » 29.07.2005 12:04
thanks, will check it
