Missing slider "Belichtung" ("Exposure")
Carsten
Unread postby Carsten » 08.08.2005 20:23
I am currently testing 3.10.2 and it seems to be missing the exposure slider that should be above the highlights and shadows sliders.
Did my PC eat it or is it a bug? In 3.0 (which installs in English language) the slider is present.
Regards,
Carsten
Unread postby Dan Kozub » 15.08.2005 18:50
Carsten,
We have hidden this slider. The same effect can be achieved now with Autocontrast sliders.
I am thinking now about returning this slider....
Guest
Unread postby Guest » 18.08.2005 17:17
Hi Dan,
yes, I think returning the slider would be a good idea ...
Carsten
Guest
Unread postby Guest » 18.08.2005 17:27
... thinking more about it, auto contrast indeed achieves all that is needed.
However, may be for user interface it is slightly more intuitive to have
- contrast range: select how much of the original contrast range you want to keep
- contrast shift: select minimum value that will be mapped to zero.
Actually, in order to be perfect, you should implement what they call a "soft knee": don't clip values below min and above max, but use a smooth curve.
So you'd add a parameter such as "contrast soft clip"
Should I explain more?
Carsten
Unread postby Dan Kozub » 18.08.2005 18:48
Carsten,
I think I understand you.
You want that the curve formed by autocontrast sliders was not a broken line but something like S-curve.
I is not simple to implement, but the most important, I do not know who would use it. I'd like to keep the program logic streight and clear
Danylo
