Conversion problem with Sony ARW format
bms44974
Unread postby bms44974 » 03.10.2008 05:02
I am using a Sony Alpha-100 and have recently noticed Helicon Filter's conversion tends to overexpose some of the lighter areas of my photos. I am attaching a jpg file to demonstrate the problem. One side is converted using Sony's image converter and the other with Helicon Filter 4.90. No adjustments or filters were applied to either conversion. Thanks for any solutions. Cheers... Brian
conversion comparison.jpg (61.67 KiB) Viewed 4938 times
tombell
Sony raw
Unread postby tombell » 06.10.2008 00:57
HF pixalates my A 350 raws.
tombell
Unread postby tombell » 06.10.2008 01:22
The new d/l 4.9 cured the pixalation. It's working fine. Great update!
bms44974
Unread postby bms44974 » 06.10.2008 03:48
The overexposure of A100 ARW files is present in HF v4.90. You must have had a different problem.
Unread postby Dan Kozub » 30.10.2008 13:49
Brian, which converter is selected in RAW settings? Adobe DNG?
bms44974
Unread postby bms44974 » 30.10.2008 22:58
Dan Kozub wrote:Brian, which converter is selected in RAW settings? Adobe DNG?
Dan,
I was using the Adobe RAW/DNG Converter with Adobe RGB color space.
I switched to Embedded RAW Converter, unchecked the Adjust Contrast and Use Camera White Balance boxes, and I now get something with all of the detail of the Sony converter.
Thanks for the tip!!!
Brian
