Mixed experience with HF 4.90
pJ2
Unread postby pJ2 » 27.09.2008 22:37
This follows the post signed PJ2
As a standalone, to process canon g9 raw with dcraw, 4.90 works smoothly,
maybe even faster than 4.84. Has there been optimization?
An old problem remains: I can't use the 'regular' raw processor, that using the canon code. This was originally the motivation for updating to 4.88.
Worse, I can't use HF from Photoshop anymore. It worked with 4.84.
With 4.90, I get the panel with hf 4.90 over the colorful background of the setting sun, and it freezes there. This had happened when I installed 4.90 and the installer offered to launch the programme right after installation.
My version is 'Helicon Filter Pro(MP). I had had the photoshop pluging running for years.
I have just checked the right .8BF file is in the photoshop pugin file.
More help will be appreciated...
Yours JPJ
Unread postby Dan Kozub » 28.09.2008 17:41
Thanks for your feedback. We cannot reproduce the problem so please contact us via support@heliconfilter.com.
Here is the link to old version, you can install it into different folder and use both versions.
http://helicon.com.ua/downloads/HeliconFilter4.84.exe
G9: we use the latest canon libraries available from canon site. Please upload your sample to our ftp server (http://heliconsoft.com/ftp.html)
pj2
promt replys 4.90=>4.84
Unread postby pj2 » 29.09.2008 10:54
Thanks for your reply.
Now, with 4.90 and 4.84 in different folders, the problem is that
4.84 is the free version and neither works as a plugin from photoshop (the answer it gave when I called it as a plugin,
nor does it process raw.(less important as 4.90 still works as a standalone.)
I need an unlock code for 4.84 pro(MP) .
What is the procedure?
Thanks. JPJ
Jean-Pierre Jugean
Unread postby Dan Kozub » 29.09.2008 16:33
Jean-Pierre,
Please contact our support (support@heliconfilter.com) and you will get your activation code in case you forget it.
We need more info because we cannot reproduce your error. We'd better make it via email.
oldsalt19
Unread postby oldsalt19 » 29.09.2008 18:38
JPJ
Perhaps Helicon admin cannot reproduce the problem, but I can: exactly like you say. HF hangs at logo when called from Photoshop. I am using an Intel duo core machine with Vista (Suprise!) I have had nothing but problems with Vista--a real nightmare.
PJ2
answer to answers
Unread postby PJ2 » 29.09.2008 21:29
Thanks to Dan, your advice will be followed, time permitting.
Thanks to oldsalt19, I am indeed using Vista on an Intel quad. It's good not to be alone.
Jean-Pierre
pj2
Now running both 4.84 and 4.90
Unread postby pj2 » 20.10.2008 12:44
Thanks to the team for their support.
I have found time to finetune and test everything.
So I process canon g9 file with 4.90 as a standalone,
using dcraw, which works fine when one knows where to find the options.
And 4.84 works as a plugin on photoshop elements, adding much needed functions.
Next, I will have a few more questions.
But the moment, it is satisfaction.
Jean-Pierre
