New Helikonfilter V4.88 fails
Kgeo
Unread postby Kgeo » 08.08.2008 16:33
Dear Helikons,
I installed the new version 4.88 of Helikonfilter. Only starting the program and loading a picture then close via "red cross" creates an "internal error! Code 1400. Invalid window handle". Then only the task manager can help. Any comments or solutions?
Kgeo
_______________________________________
PC: SCALEO Hi 2553 (Quad core CPU Q6600)
Graphics: nVidia GeForce 8600GS 512 MB
OS: Vista Home Premium, SP2
Kgeo
Unread postby Kgeo » 09.08.2008 12:37
Additional remark: it would be nice to have one or two older versions
in the download area available to reinstall an older version in such cases.
Unfortunately I lost the setup file of the version 4.87 ;-((
Kgeo
Unread postby Dan Kozub » 10.08.2008 19:47
Here is the link to old verison:
http://downloads.heliconfilter.com/Heli ... 4.87.1.exe
And this one is for updated 4.88 version:
http://downloads.heliconfilter.com/Heli ... 4.88.2.exe
We fixed some other bug but maybe your bug is gone too?
Kgeo
Unread postby Kgeo » 11.08.2008 10:23
Hi Dan,
thank you for the links. I installed the v4.88 _ 2 version, but the result is the same as described in my first message (error code 1400). I only can terminate the Heliconfilter using the task manager ;-((
Hopefully you can solve the problem?
I reinstalled the v 4.87 and a short test shows that it is running well...
Kgeo
jpmccormac
Same Issue Here - error code 1400
Unread postby jpmccormac » 12.08.2008 20:17
I installed ver. 4.88 and am having the same problem. I can only terminate the program from the task manager. I'm running Win XP Home edition.
Kgeo wrote:Hi Dan,
mopsz
Bug on 4.88
Unread postby mopsz » 15.08.2008 11:20
I installed ver. 4.88.2 and am having the same problem.
Vista and XP
Unread postby Dan Kozub » 15.08.2008 13:57
we are working on it...
BobPhoto
Any Update
Unread postby BobPhoto » 11.09.2008 15:44
I also have this problem and it is very annoying. Any update as to a fix? It's been over a month now that his issue was first reported. Thanks
Unread postby Dan Kozub » 15.09.2008 12:13
You can use this version so far:
We expect new version to be published in a few days.
kentel
Unread postby kentel » 16.09.2008 22:28
I'm using 4.88 with XP Home and SP3, with no problems. Am I just lucky?
KT
openbox
Unstable HF4.88
Unread postby openbox » 24.09.2008 00:40
kentel wrote:I'm using 4.88 with XP Home and SP3, with no problems. Am I just lucky?
Most likely, you are :) Because I have the same problem with this version on WinXP SP3. Unfortunately, HF4.88 is very unstable :((
kentel
Unread postby kentel » 24.09.2008 13:14
Strange, with my XP SP3, I have now processed over 700 images using 4.88 with out any problems.
Maybe there is a conflict with another program you have running.
KT
Guest
Unread postby Guest » 27.09.2008 05:17
May be, but previous version I used did not conflict with any other app in my system.
Unread postby Dan Kozub » 27.09.2008 08:46
We already published 4.90 with these bugs fixed. Sorry it tooks so long.
