Pictures aren't deleted to the bin
Guest
Unread postby Guest » 01.07.2008 22:40
I think formerly it was different and deleted files were moved to the bin, but now they are deleted directly and can't be restored from the bin.
I can't find any possibility to change this behavior. Is it a bug or is it a feature? May be it occoured after a restoring of the OS (WinXP Home SP1) from a HDD-image?? I use version 4.68.1. Re-installing the program didn't solve the problem.
Thank you!
Unread postby Dan Kozub » 02.07.2008 10:28
In the current version we delete files without trash bin. I will put this issue to our to-do list.
Guest
Unread postby Guest » 02.07.2008 12:34
Thank you very much - that would be a fine feature, especialy if there would be the possibility to choose if pictures should be deleted directly or into the bin!
Users browsing this forum: Exabot [Bot] and 7 guests
