Black Point effect jumps!?
firexball
Unread postby firexball » 02.11.2007 11:21
Hello Danylo!
I recognized, that the "effect" of the black-point-slider jumps. Between the values 0..2 there is no difference in the effect (in the picture). Form 2->3 there is a "bigger" jump in the effect and form 3..5 there is also no effect. This is going on up to a value of 22. From there, every value has a specific change in the picture. The red clipping mark in the Equalizer changes by every value, but you can also see the "jumping" in the curve!
I think this is since the change to linear... :oops:
Greetings firexball
Unread postby Dan Kozub » 04.11.2007 22:09
Yes, you are right. After changing to linear space the black point is gamma-decoded and this causes rounding errors. We will see if this can be fixed.
Thanks for reporting! : ) no one else would notice it : )
